SignUp Now!Since you're really not planning to do more than a rebuild right now the one thing you might think about is going with taller ball joints which helps the camber curve in the car. A 1" difference will help the handling and if you do a 1/2" taller top and bottom it will drop the front 1' or yo can do stock on top and a 1" taller on the bottom which will drop the front down 1". It's a little more expensive than a stock ball joint but it helps keep the car on the road in curves better.
Are there any downsides to doing that? Rubbing? Do you have the right part numbers? Thanks.
