TurboBrian
- Jul 24, 2013
So I got my 86 gn running like this. Supposedly with new 42lb injectors aftermarket chip, fuel pump and a bunch of other stuff so the previous guy was definitely trying to fix the problem. My base fuel pressure is around 20lbs and maybe 25 with the vaccumm line disconnected and the pressure falls when I step on the gas, and when I turn it off the pressure on the gauge doeent hold it immediately goes to 0. I thought my bosch 237 regulator was bad so I just bought an accufab adjustable off the for sale section and a brand spanking new fuel filter and it didnt change anything. The problem has gotten worse since ive got it, it idles like junk, light throttle is jumpy and wot feels like the up pipe coupler is busted through ( its not ) ... the turbo spools up but the car falls on its face. Worst thing is I dont have a scan master or even boost gauge and on a really tight budget. I know running the car lean is a no no but can it be driven if babied? Its a daily driver. If It helps one day it was running perfect until I went to fill it up and also put gumout fuel system cleaner in it and it started back again. So my question is whats the next step? Could the sock in the tank be clogged or a fuel line itself be clogged? Any help is greatly appreciated
