- Feb 18, 2006
You can lead a horse to water but you can’t make him jump in. Good luck
Now comes the "ya, but" scenario....You can lead a horse to water but you can’t make him jump in. Good luck
run a stainless mesh filter with a 100 micron filter and solve that problem. You can even run it in the same location
Chuck Leeper. Ya But.I have run stock lines on e85 into the high 9s with no problems, stock filter as well. I cut it apart after 2 seasons and it was perfect inside. Either your filter is dirty, or the pump is bad. I could see at 20 psi you might be pushing a 340lph pump to its limits, not beyond, but at 16psi, you are not. There is a lot of bad info out there on e85. I have been running it since 2013, never had any of the issues people say.
I put a brand new filter on. Same problem. Is this where you tell me the e85 broke down that brand new filter after 1 minute? Talk about hard headed and “yeah but”..Now comes the "ya, but" scenario....
I'm done.
I made no reference to a new filter.Is this where you tell me the e85 broke down that brand new filter after 1 minute?
do you have ANY useful isldeas now that I’ve eliminated the filter. Or was the filter the extent of your expertise? . If not go troll someone else’s thread.I made no reference to a new filter.
The comment was in reference to a 10 yo filter.
Oh ya, the ya but stands.
“Toxic old Bastard” . I have it figured out. With no help from your brilliant fuel filter soution."If not go troll someone else’s thread".
I have nothing to add, at least that I'd share with you.
As far as your troll comment.....
I don't give a shit if you ever find out what's causing the issue.
And what did you figure out?“Toxic old Bastard” . I have it figured out. With no help from your brilliant fuel filter soution.
The Dw300 pump just isn’t enough to keep up with my set up. 95lb injectors/ 22lbs boost.And what did you figure out?
I’m going Hellcat and new lines.As you up boost the boost the pressure will not match 1to1.
Usually the pump cant keep up.
Look at aeromotive brushless spur while your shoppingI’m going Hellcat and new lines.
