Fuel pump output and max injector size
Soldier_GN
Hey Guys,
Im doing some head and roller cam work on the GN, finally. Wanted to upgrade my injectors, currently running 42.5# injectors. I have a Walbro 255 in the tank and was wondering if that fuel pump would support 80# injectors at 25-28 PSI?
1 Gallon = 3.785 liters
255 LPH Fuel Pump divided by 3.785 Lieters = 67.31 gallons
Now How do i add a conversion or factor in the 80# injectors and 25-28 PSI
Will my Walbro 255 work with these 80# injectors or will have to upgrade the pump too???
There is more than a few variables at play as the fuel pump flows diferently at didn't pressures.
http://autoperformanceengineering.com/html/fpspecs.html
You need to consider your base vs actual fuel pressure...if your base fuel pressure is 43.5, then at 25psi, the fuel pressure is 78.5 - then go find a chart that shows the 255 lph pump output at this pressure. but then you're still not done.
how much HP are you trying to push at 25psi? psi is just a figure and isn't an indicator of power by itself.
Putting all of this aside, looking at your combo, you may want to consider 60lb injectors unless you plan on a bigger turbo later on. 60lbers can get you to mid 10's, then you'll need more for faster.
Awesome...so i can run the 80# but in the future when i upgrade my turbo i will need to upgrade the fp...
Only reason i wana make the change is because my 42# were running at 95% duty cycle...so im good for the time being...thanks guys
