Fuel pump recommendations
Discussion in 'Engine Tech' started by wb_7354, Jul 16, 2017.
  1. wb_7354
    wb_7354
    Expand Collapse
    May 31, 2008
    278
    38
    Online
    I'm currently running Reds XP plus Hotwired. It's probably 10 years old. I'm upgrading my combo. Full roller, Champion irons, 206/206 cam, Champion intake. I might go E85 at some point. What do you guys like/ dislike and why?
  2. DSEROVY
    DSEROVY
    Expand Collapse
    Aug 1, 2004
    87
    1
    Online
    Last car had a Racetronix Dual 340 kit using oem lines.
    Rock solid pressure on a 10 sec build logging with transducer and PowerLogger.
    Going with this again on my new build, although I'm probably going with AN fittings/lines this time just because I butchered the fuel lines on this car a LONG time ago!
  3. Nick Micale
    Nick Micale
    Expand Collapse
    Tech Advisor
    Staff Member
    May 26, 2001
    8,307
    1,293
    Offline
    A DW 301 pump will out perform a Walbro pump according testing by Richard Clark.
    It is also the only in-tank pump that carries a 3 year unlimited warranty.
  4. Steve V
    Steve V
    Expand Collapse
    Steve V's Automotive 757 560 2782
    Jan 5, 2004
    3,796
    170
    Offline
    Dw300 is what I have. It needs a return line mod and 3 yr warranty like Nick says. Run a good ground to the block for your pump--credit to Bison for that tip.
  5. wb_7354
    wb_7354
    Expand Collapse
    May 31, 2008
    278
    38
    Online
    Do you sell the DW300 Nick?
  6. dank GN
    dank GN
    Expand Collapse
    BlackArts Automotive (661)993-8277
    Jan 11, 2009
    2,838
    243
    Offline
    I am running a single walbro 430 with -8 supply and -6 return . its good for e85 and I have put down 580 with that setup and 120lbs injectors maxed out on e85
  7. ttypewhite
    ttypewhite
    Expand Collapse
    Oct 1, 2001
    3,027
    345
    Offline
    I run a Racetronix double pumper and line kit. I have run bottom 9's at over 154mph with a 68% duty cycle in a full weight street car. This will more than likely be the last fuel system that I will put in my street car. Very pleased with it, and have lots of room for growth.
    • Like Like x 1
  8. wb_7354
    wb_7354
    Expand Collapse
    May 31, 2008
    278
    38
    Online
    Thanks for the tip Steve V and Bison too.
  9. Nick Micale
    Nick Micale
    Expand Collapse
    Tech Advisor
    Staff Member
    May 26, 2001
    8,307
    1,293
    Offline
    Yes, I am a distributor for DW.
    A GN with one DW 300 in-tank pump has run a 9.90 in the quarter mile with enhanced voltage and alky injection!
    Not all turbo cars need a return line mod when using the DW pump. We have 11 sec. GN's running stock lines with a DW pump.
    Additional testing by Richard Clark with a DW 301 pump vs. a Walbro 450L pump is equal in flow/output.
    We will very soon be testing a new DW 450 pump which has shown to exceed the performance of the Walbro 450 pump!
  10. Steve V
    Steve V
    Expand Collapse
    Jan 5, 2004
    3,796
    170
    Offline
    Dw200 didn't need any mods, but my dw300 did. It's a 340lph. I run a volt booster as well.
  11. Ed Valvo
    Ed Valvo
    Expand Collapse
    May 25, 2001
    787
    6
    Offline
    Seen a DW300 go 133 mph in the 1/4 mile on a full weight GN and no alky. Fuel lines were -6 and had a volt booster.
  12. belsie
    belsie
    Expand Collapse
    May 16, 2011
    768
    28
    Online
Share This Page
