dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
okay I have a issue with my relay , I turn the ignition on and wait 2-4seconds till I here it click . Then turn over the motor . The motor will start then will die because the relay will click on and off . With that said my fuel pump continues to supply fuel at the proper pressure. So why would it clicking on and off cause it to kill the spark ? Where does the signal come from to close the relay ? What supply's the power to it ? I have the oil pressure switch bypassed . My main power breakout on the starter are secure . Any idea would be great .
