SignUp Now!People want a a "warp driven star ship" fueled with a rickshaw fuel system. The fuel sytem is insurance on your investment.Mike, you spent a ton of $$$$ on your engine, and you are going to trust any in-tank stock fuel pump, or even 2 of them to perform and be reliable at 800 HP?
Do it right the first time, and install a 1000 HP system and never look back as you will have a good safety margin, and it will be very reliable.
How many times have you seen one of the double pumps fail at the wrong time with disastrous results? Not many, because people do not post their mistakes, but I have seen it happen many times.
Make sure it is done RIGHT the first time, which will cost very little more, and even less, if the first system does not perform to your expectations.![]()
The biggest restriction in the feed line is the fuel filter,not the line.Overcoming the inherent restrictions in the system is tough to do,the biggest restrictions being in the lines that run up the front of the engine to the fuel rails on the engine.
The same fuel filter that Red Armstrong uses along with the stock unmodified feed and return lines that feed his 1,000 hp motor running on gasoline.
His 1,000 hp system is done "the wrong way" and continues to do the job. Imagine what the right way would do.
The same thing. It would just cost a lot more.
The return line isn't restrictive at all if you don't send 700 hp worth of fuel to the motor while it is idling.
There is never a need to modify or replace the return line.
Do I need to run a controller with the Weldon? So from the tank I can run -8 to a -6 AFPR and duel feed the Champion rails with -6? Is that enough? Thanks!
Ok,this huge restriction is in my car and Red Armstrong's 1,000 hp fuel system. Guess how much fuel Red is able to run through this restrictive line. 1,000 hp worth. I run the equivalent of 920hp on gasoline through this same restrictor. How much power are you producing? If it's less than 1,000.you don't need to replace or modify this line.There's more restriction in that section of line than the rest of the system from the tank to front of the fame rail,as per Jack at Racetronix.
It is,but that's not important. The thing that you cant deny is that the stock fuel line supports 1,000. Many on this site think it's risky to feed a 500 hp motor this way and cause people to spend money on things that are unnecessary.All B/S aside,the comment you made was that the biggest restriction on the feed of the system was the fuel filter..
I doesn't matter what kind of motor or how much money was spent on it. The OP wants a system to support 800 hp. He's going to waste a lot of money dispite the facts. Hopefully someone else who reads this won't.Is saving $200 in fuel line worth risking a $15k stage 2 motor that has unreplaceable parts? I'm sure its possible, but is that the place to save money?
............ He's going to waste a lot of money dispite the facts. Hopefully someone else who reads this won't.
Please quote something I said with a detailed description of why it isn't true. This will be helpful to anyone who might read this.Hopefully someone reading this will NOT believe all your BS.
Why do you put 700hp fuel pumps in stock Buicks?How many 8, 9 and 10 sec. GN's have you actually built and have the experience to back it up?
I feel like a retard, so the feed line goes straight to the passenger side and the return goes the to AFPR?
