The_Six
- Feb 28, 2009
Ok ordered most of my new fuel system parts today but have some questions.
I’m going to be running a in tank pump and will have -8 line to a Y then run -6 to both rails. Then run -6 to en external regulator and then a -6 return to tank.
I am going to modify the original fuel pick up so that it will have a -8 feed fitting on the feed line and was wondering if I should do the same with the return and the -6 or just add a -6 bulk head to the tank.
Also would it be ok to put my fuel pressure gauge sending unit before the Y I know its normally in the regulator but I like to hide wiring if possible and if it’s before the Y then it will be one less sensor and wiring seen.
I’m only doing this because I had to replace the return line any way I was going to just use the old feed line as a return but decided since I’m there may as well replace it all now plus it will look cool.
