87turbot-type
wo2
- Sep 2, 2007
Well it's finally time for me to put my car back together.
I am ready to order my roller cam setup. and would like some opinons
My combo will be
bottom
Stock crank, with girdle
h-beams
.020 forged pistons
top end
gn1 intake, 60#, 70mm tb
stock heads (I would like to switch to gn1's by the end of the season staying in my budget for now)
other notibles
ptc 10" 3200
cottons front mount
no ac
ta headers
6076 journal turbo
tt chip
4" maf pipe
stage 1 trans
I've been reading alot about staying with the smaller setup cam. I know last year when I switched to the roller rockers that I had to shorten my pushrods, so I will probably have to order some different size pushrods than come in the kit. I had the comp 212/212 hyd cam last year and it ran well. I am running a smaller turbo (6076) to try to get some better streetability out of the car.
My goals will be by the end of the season to run some low 11 second passes with the boost up.
Keeping in mind that I would like to have the gn1 heads by the end of the season, which size grind would you guys suggest?
Also which lifters would you suggest? Morel or comp.
Thanks for input!
My combo will be
bottom
h-beams
.020 forged pistons
top end
other notibles
ptc 10" 3200
cottons front mount
no ac
ta headers
6076 journal turbo
tt chip
4" maf pipe
stage 1 trans
Thanks for input!
