This may not be a bright idea, and I can't remember where I read it.
I read that the extra 3-4 qts of trans fluid that is trapped inside the torque converter & trans case, can be purged out by idling the engine & letting the internal trans hydraulic pump mostly empty the trans, by leaving the pan's drain plug removed (if you have one) or by running the cooler lines into a jug.
does this seem wise? you wouldn't run the engine without oil !
on the other hand, there's not much load on an idle trans, and it doesn't get hot unless you drive it around.
