Dusty Bradford
- May 24, 2001
PT1800 built to mount under the dash. 5 gallon water tank with a 500gph pump. BMR aluminum block off plate with 4" aluminum tubing welded so the whole assembly becomes part of the firewall when bolted in. V-band connections on the intercooler and includes Turbonetics Godzilla blow off valve. Supports 1800hp with temps under 100 degrees.
$1500
$1500
