DJackson1357
- Mar 15, 2010
Trying to clean up the garage a bit (plus trying to fund a roller cam after wiping the flat tappet).
PTE Stock Location Intercooler – Less than 10K on it. Intercooler is in great shape, the scoop has some minor damage from road use but nothing significant. Had to make some slight modifications to one of the mounts due to engine differences. Should still work fine on a car with the stock hardware. Up-pipe to throttle body does have a hole drilled for alcohol injection. $550
PTE Upper Plenum w/ Powerplate – Polished version of the plenum, has some slight scratches from being installed/removed a few times. $150
Set of 8445 Buick V6 Heads – Fresh valve job, the valve guides or seals would need replaced though. They puffed a bit of smoke at start up. $75
Rolled Fillet Buick Crank – Came out of a 4.1, looks to be standard size on both the rod and mains. Will need .010 to clean up. $150
484 casting number Buick 4.1 block – Cylinders are a bit rusty from sitting for a few years, it is standard bore though. $100
17058253 Quadrajet – Came off of a 1978 403 that was in a Olds 98. $100
Small Block Chevy HEI – Non-Computer controlled, worked fine when it was last ran a few years ago. $25
TH-200-4R 10 Tooth (Green) Speedo Drive gear – Factory drive gear for 3.73 rear gears. Good shape. $50
CVR mini-starter for SBC – $40
3” Ultraflow muffler – Offset / Center. $30
TH-200-4R trans – Rebuilt by a local builder 10 years ago, has 40K or so on it when pulled. Does have a Monte SS valve body and governor as well as a Trans Go shift kit. $150
BOP TH-400 – pulled from a 78 Olds 98 with a 403. Not sure of the condition, owner said it ran and shifted fine. Fluid looked original. Comes with torque converter and output shaft yoke. $100
Single row F-body aluminum radiator with aux trans cooler – Used on a G-body until I sold the car, maybe 20K on it. $40
Prices are negotiable, if you’re interested in something let me know. Check my photobucket page for pictures. http://s273.photobucket.com/profile/DJackson1357
Email me at DJackson1357@yahoo.com if you have any questions on anything. Thanks.
