sixequalseight
- Jan 8, 2007
I'm in the process of doing a new water pump/timing chain/cover/cam button/oil pump/oil pump cover on my '84 GN engine, all stock. All above components are new, either aftermarket (water pump/timing chain/oil pump/cam button) or GM (timing cover/oil pump cover) Should I use any adhesive on the oil pump cover gasket?
Also, I have a stock GM oil pump and a melling HV oil pump. The engine is older and runs great, and I know there is some debate about the advantage/disadvantage of the benefits of runnning the HV pump. Engine milage is unknown, but it is nice and clean inside and seemed to have good oil pressure before I took it apart. Should I run the HV or stock oil pump?
