SignUp Now!Mine isn't being used because I had problems with the pressure regulator working with the homemade block. I've since bought a mill and machined down a stock adapter and threaded it for the output fitting.Thanks great input! Are these covers currently being used? I think I would like to make one for my stage2.
Nick,Just thought I would give my comments on a gerotor pump set-up for a turbo V-6 after investigating this possibility.
First comment is that after building and working on 8 and 9 sec Buicks with stock type oil systems with mods, we have found them very reliable and give outstanding performance.
Beyond that level, racers will then go with a dry sump system.
Since a gerotor system would require modified and fabricated parts, the reliability factor woud be questionable as compared to the proven stock system.
With the new pumps and covers developed by TA, it has elevated the stock type oiling system to a higher level of performance and reliability.
A major issue I have with the gerotor set up is not being able to quickly and easily run oil pressure for priming or testing.
We are really discussing performance applications here as there is no good reason to adapt this to a street driven GN except to be different. A stock type system is more than adaquate.
I know my info sounds negative, but I try to look at all aspects of developments - good or bad.
Nick,
I built mine part because I could and part because .................
