I will sell the remaining items later this winter in a different post. Thanks to everyone who made a purchase! The items that were sold are shown below for future searches.
ITEMS THAT ARE SOLD (FOR RECORDS ONLY)
1.California Car Cover – Noah Style, custom fit for the GN. Includes mirror pockets and the grommets for the antenna cut-out (not installed). Used for a little over one year. Excellent condition. $175.00. (SOLD/SHIPPED)
2.GNS custom fender cover, with mesh screen to allow air to flow to grill while the car is running. Includes original accessory bag. No photo, can see it here:http://www.gnsperformance.com/products/fender_cover.html $100.00 (SOLD/SHIPPED)
3. TA49 Hybrid Turbo – rebuilt by PTE over the winter. This is a TA49 turbo with two changes: 1) the cast compressor wheel has been replaced with a more modern (and efficient) 58mm MFS wheel, 2) the wastegate hole has been ported. Does not include inlet bell or actuator (however, I am selling two adjustable actuators below). See photos. Zero miles – never installed on a car. $600.00 (SOLD/SHIPPED)
7.RJC Power Plate for stock plenum, not yet drilled for EGR, no gaskets - $40.00 (SOLD/SHIPPED)
8.Kirban’s 4-Piece Rubber Heater Hose Kit – NIB. EXCEPT the metal-line-to-water-pump hose has been replaced with the hard-to-find “S” bypass hose. See photo. $35.00 (SOLD/SHIPPED)
10. Adjustable wastegate actuator – used, good condition - $50.00 (SOLD/SHIPPED)
11.Set of 4 Upper Control Arm Bushings – never used - $10.00 (SOLD/SHIPPED)
12.Front Sway Bar End Link Bushings – All 8, never used - $5.00 (SOLD/SHIPPED)
13.Polygraphite Rear Upper Coil Spring Isolators – NIB - $10.00 (SOLD/SHIPPED)
14.T-Handle for Wastegate Actuator – Use this to remove your hot wastegate actuator from the rod. Custom-modified with duct tape to cushion your fingers! $7.50 (SOLD/SHIPPED)
15.Caspers 24” MAT Extension Harness – never installed - $15.00 (SOLD/SHIPPED)
18.Billet Adjustable FPR – Used, could use a polish, was working on my car earlier this year, includes allen wrench to adjust - $50.00 (SOLD/SHIPPED)
19.RemFlex Exhaust Gasket Set – Includes both header gaskets and turbo-to-header gasket, NIB - $35.00 (SOLD/SHIPPED)
20.2X Fel-Pro EGR Valve Gaskets - $2.00 (SOLD/SHIPPED)
21.Fuel Line O-Ring Kit - $1.00 (SOLD/SHIPPED)
22.Plenum Gasket - $3.00 (SOLD/SHIPPED)
23.Throttle Body Gasket Kit for 62mm – Includes TB-to-plenum, vacuum block, and IAC gaskets - $5.00 (SOLD/SHIPPED)
24.Pack of 5 Turbo Oil Drain Gaskets - $10.00 (SOLD/SHIPPED)
25.AC-Delco 14547S “S” Hose – NOT the actual “S” hose for our cars, but a very similar one that is said to work fine - $5.00 (SOLD/SHIPPED)
27.Remanufactured Stock MAF – I installed this to pass Indiana emissions test, maybe used a little more, definitely has less than 1000 miles. Correct downward-facing connector. $35.00 (SOLD/SHIPPED)
28.GBody Parts Turbo Oil Drain – used briefly (maybe 100 miles), hose already cut to proper length, looks brand new - $35.00 (SOLD/SHIPPED)
30.Generic 8mm Silicone Spark Plug Wire Set – slightly used, still look very good, grey with black boots - $10.00 (SOLD/SHIPPED)
31.RJC PCV Valve – lightly used, still looks new - $15.00 (SOLD/SHIPPED)
Thanks for looking!
Mike
Thanks for looking!
Mike
