SignUp Now!I don't run it and i just drained my engine of all fluids. I just refilled it with distilled water and antifreeze. I can't speak for everyone but i've heard people say if it didn't come with it don't put it in. I also read this.
GM Owners Still Steaming Over Dex-Cool
Ive heard of this before. Im convinced this may be a grounding issue where the current eats through the gasket sealing surface or some kind of electrolytic action that destroys part of the gasket.How many of you have seen a late model Dodge pick up leaking and it isn't condensation from the A/C system? For some strange reason they leak on the passenger side head at the rear.
99 Silverado 158,000 Miles, Used dex cool exclusively, No sludge
03 Pontiac GTP 80,000 Miles Used Dex cool exclusively, No sludge.
Like the 10,000 Mile oil and the 100,000 Mile Platinum spark plugs. 100,000 Mile coolant is a myth. You have to keep an eye on it and change it when needed.
Charlie, Ever tried these things. Seems like the way to avoid acide corrosion of the coolant systems.
On another note I pulled the radiator out of the regal with the engine change. 7 years old and fed a steady diet of RMI-25. Clean as a whistle.
