I want to install a #8 fitting on the inlet side of the fuel rail. Has any one done this? And if so what did you use? Not sure if the rail is NPT or not. Thanks James
If those adapters from Ramchargers do fit, I would think, because of the small hole in the stock inlet, there is no benefit to using a much larger -8 supply line?
