gunzandgearz
gearzandgunz
- Aug 24, 2015
Did you use head studs and chamfer the top of the head bolt holes or just use bolts
SignUp Now!With these modern turbos you might have to buy one that will support 1,000 hp just to loose enough response. I've come to the conclusion that I need an external wastegate with a more advanced electronic boost controller to reel in some of that low end torque or 2 big boned girls in the trunk.No I will probably stroke it and do like you and run a narrow spread camshaft in a little bit bigger turbo than what I need to help bleed awesome bottom end
Yes,and don't torque over 70 ft/lbs.Did you use head studs and chamfer the top of the head bolt holes or just use bolts
yes.Did you use head studs and chamfer the top of the head bolt holes or just use bolts
You do that first so the second time it will stick. I can do nothing in first gear,but I've never tried doing a good burnout and then leaving on the fresh sticky black lines. I'm talking on the street.Ha that's some funny crap right there, that's what I'm afraid of traction, I'll bet that thing will light up the tires at 40 huh
I've never been to the track. The turbo is said to support 730hp,so it is probably right there. The people who bring the portable dyno to our city's annual car event " Back To The Bricks " Flint,Michigan didn't show up last summer,so I don't even have a dyno number.How much power and have you had it to the track
Cool.I'll pm you tommorow so we don't jack this thread up anymore
Why notI can get this back on track. The TA and Champion heads have equal potential. Don't use them on a 5,500 rpm 235 cu.in. Buick.
Now we are really talking,I like bothIt turns out that all you have to do is turn up the boost or increase the bore and stroke of the engine.
Oh now you show up where have all of you knuckle heads been this is how people learn I know I know secrets secretsNow we are really talking,I like both![]()
In the race game you have to have themOh now you show up where have all of you knuckle heads been this is how people learn I know I know secrets secrets![]()
I know I probably should shut up now, after all I grudge race quite often probably shouldn't give up the tricks in my bag that's taken me years to aquireIn the race game you have to have them![]()
I'm still wondering why some of the real fast experts haven't jumped in and told me how wrong I am not that I believe I am just wondering why no one has jumped on this conversation, as I do believe that is how people learn, anyway not going to say anything else about the subject, unless someone tells me that I'm full of crap then we'll see as I think there needs to be more discussion on this board, I think it has died and I don't want to see that
