SignUp Now!the turbo makes the power. specifically the compressor ,shaft speed and size of the wheels being used,the engine has to be able to swallow it/in and out.the motor does not know if its an na or forced induction motor.the better the motor/air pump/VE/, the better the system can work.I would bet a paycheck that on a turbo motor, minimizing pressure drop on the heads is more important than intake port velocity.
That is correct when cylinder heads are ported for Max effort engines they are ported the same exact way you would a naturally-aspirated engine makes no difference ,in other words you don't Port them differently for a blown or turbo charged application valve size is determined by bore size, and port volume and velocity will be determined by engine rpm, it has to be a match system cam heads turbo cubic inches everything has to be taken into consideration but mainly bore size stroke and RPM plus turbo size has a lot to do with how it's all set upthe turbo makes the power. specifically the compressor ,shaft speed and size of the wheels being used,the engine has to be able to swallow it/in and out.the motor does not know if its an na or forced induction motor.the better the motor/air pump/VE/, the better the system can work.
I got a question , isn't more important to port the exhaust vs intake side on heads unless you have a ported intake manifoldThat is correct when cylinder heads are ported for Max effort engines they are ported the same exact way you would a naturally-aspirated engine makes no difference ,in other words you don't Port them differently for a blown or turbo charged application valve size is determined by bore size, and port volume and velocity will be determined by engine rpm, it has to be a match system cam heads turbo cubic inches everything has to be taken into consideration but mainly bore size stroke and RPM plus turbo size has a lot to do with how it's all set up
The answer to this should be very interesting.I got a question , isn't more important to port the exhaust vs intake side on heads unless you have a ported intake manifold
Not sure I understand that question if you're going to Port the heads the intake manifold has got to match the intake runner,but not 100% certain that's what you are afterI got a question , isn't more important to port the exhaust vs intake side on heads unless you have a ported intake manifold
Well you can forget the polishing part cuz that's worthless as tits on a boar hog you can do it on ex. Side but never on intake sideand me personally I would never Port exhaust side without doing the complete headsI Was always under the impression that when you port and polish heads the exhaust side was the most important , I guess I was wondering if you don't have a ported /polished intake manifold why would you need the intake side on the heads to be ported or will you benefit from just porting/polishing exhaust side on heads
ok that's what I meant polishing intake side my bad, thanks for confirming, tits on a boar lolWell you can forget the polishing part cuz that's worthless as tits on a boar hog you can do it on ex. Side but never on intake sideand me personally I would never Port exhaust side without doing the complete heads
Not your bad at all anytime I can help by the way I'm sure some will disagree with me and and that's fine I'm sure they'll be here telling me about it before longok that's what I meant polishing intake side my bad, thanks for confirming, tits on a boar lol
Yeah whats funny is if you can hang with guys that build the baddest engines out there ie NHRA pro stock nascar,pro mod you can pick up alot of good info,again not that I know everything out there, but I have hung with and still do hang with a couple of the best induction system experts in the country and they have schooled me on alotyes indeed I have some irons that have been ported but not polished just curious about that I also have been told that some prefer some turbulence on intake pending application
Thanks for the kind words, I wish I could do more building like you and less talking. I am slowly getting my car back together.Nigel based on your latest response and past conversations with you I have no doubt that you have extraordinary knowledge of flow.
You would be a great person to have on a development team. While porting my own heads some of your ideas regarding "entrainment" were considered.
The thing I would consider is that the turbine, compressor, and reciprocating engine all are a single system, so you have to consider it as whole.the turbo makes the power. specifically the compressor ,shaft speed and size of the wheels being used,the engine has to be able to swallow it/in and out.the motor does not know if its an na or forced induction motor.the better the motor/air pump/VE/, the better the system can work.
when you run out of compressor the power is done,all the things you are discussing are overlapping,its not a tradeoff.maxing out a turbo would require the engine to be optimized for that power range or the turbo will never see its limit.When you run out on the compressor map, you cannot make it up with port velocity. Maybe I am wrong,
Maximizing the compressor/turbine combination for a given engine will outweigh other considerations, so long as the head/cam design is correct for the turbo mass flow capability. ---
