scot w.
GNSperformance.com
- Feb 19, 2005
Thanks Aaron! Your the man!! LOL
SignUp Now!So that was an easy fix!!! Thanks Aaron.
Scot, may need to revise the instructions for people with digi rears already.
This is why I love this board!
Not sure why, maybe just a simple error. Here's the page:No problem.... I wonder why the instructions said to mount the units at the front.... I did the initial testing for Scot/Mike and I mounted them to the rear harness....which worked [confused]
oh well. At least we figured it out.... hopefully others find this post before everyone installs them up front. Glad it worked for you.
aaron
here's a small write-up.... hopefully it helps someone.
aaron
Glad you got them working! Spaghetti wrote the instructions and did the revised version as well but I wrote them and informed them of this post and the issues so i'm sure they will get them fixed up...So that was an easy fix!!! Thanks Aaron.
Can you post those up or email them out.Just received the new up-dated instructions from the manufacture and they are revised to show how to install the resistors in the rear of the car. Thanks again Aaron!
Sorry I'm late replying, family was in town and we were in the mountains with No cell service! lol I can forward them but they lack a few things like the templates..... If you have the templates it would be no problem!Can you post those up or email them out.
PM me you phone number and I will have it taken care of right away for you!ok finally got time to try and install front led's again. Everything is working properly now.
Only thing is one of the boards isn't lighting all the way. Is there any thing I can do to fix this?View attachment 160277
SW.
Dave,Has everyone been shipped the fix, I haven't seen anything yet scot
Hi Roger,Scott,
I have the digitails, look great. Spaghetti helped me troubleshoot a very rare issue.
What/how does the front led setup work - sequential / both lights work on turn / etc?
After reading this post you got me thinking so I decided to go out to the shop and see what was causing this issue.Went out last night to test everything out. Worked great!!! Only thing is my dash blinker lights stay on all the time when the headlights are on. They're dim, but stay on. When the blinkers are activated, the dash light side I activated turns brighter. Didn't notice it in the daytime. Maybe need to keep bulbs in the small sockets up front? These cars will be the death of me, lol
Keep in mind this issue ONLY happens with our Front & Rear LED's installed on the Buick's!!!
I contacted my good friend from here (GaryK1970) and he explained to me what the function of those wires do and he nailed it. It seems the way these cars were wired from the factory this little front Side marker/turn signal 194 bulb actually flashes Opposite of the other front turn signals and because of that it causes a problem with the interior Turn signal indicators. Gary will chime in i'm sure but to solve this problem of the turn signal indicators staying on I removed the headlight bezels and removed the small 194 bulb from the side marker light, then I cut the black wire going to each one (Indicators in dash are now Out).... This will make those bulbs inoperable but if you then take a small piece of black wire and attach it to the bulb end and run it to a good body/chassis ground the bulb will light up when the head lights are on, the interior turn signal indicators will operate properly now...
NOTE: The ONLY downfall to doing this is the small side marker/turn light will only remain lit while the lights are on, It WILL NOT FLASH anymore because it was removed from the harness and it's function...Gary & I plan to keep doing some testing on this silly little side marker/turn signal light to hopefully get it to operate properly without having to completely disable it's function..
Gary K,
Thank you for all your help, advice and knowledge !!
Scot W.
