GNS Performance
"Turbo-T"
V6 on steroids
I recently ordered one of GNS Performance's tach brackets....here's a link to the original thread:
http://www.turbobuick.com/forums/advertiser-specials/300319-new-hidden-tach-bracket.html
I placed my order and had it 2 days later. Very well pleased with the product. Sure you can make them yourself, but this will save you time and hassle of fabbing one up. Well worth the money.
Installation is easy...there's 2 holes drilled, you utilize one of the bolts that holds on the gauge cluster assembly, and then you drill another one and secure it down with a supplied sheet metal screw.
Here's a few pics I snapped to give you an idea...
Thanks for the kind words!
Very cool, Another good use for the bracket! :biggrin:
PS: Now if you would remove that convoluted tubing thats covering the wires and you ran them down your bracket and then pretty much behind or bracket you will have your wires all hidden then when you re-install the dash surround you won't see anything! ;)
SW.
I would hide the wires like this..
That is a damn nice piece, and I like the "alligator teeth" the way it looks you can pivot it slightly to fit.
