- Jan 21, 2007
It is easy….. you just pop of the front bezel assembly the same as the production base vehicle and you can access the bulbs. The only issue you may have is the clips tend to fall out when you pull off the bezel. Regards rick
P.S. you may want to try using a fuse puller for taking out the bulbs....
