SignUp Now!Rick and I spoke the other night and the ball is rolling!You and Scot W. need to hook up and see about marketing them together Rick.![]()
Mike they should allow more clearance for guy's running wider front tires. That was the whole purpose for them back in the day because the GNX had wider front tires than a GN.Hey guys, is there any idea as to what size wheel/tire will be able to fit with these panels in place? I know they were intended to make room for the 16's on the GNX, but with modern 17 and 18" wheels, what do you think will be able to fit now? Will this open up room for wider front wheels than what most have run so far or just make it easier to run what guys have been able to run? Just curious!
Now I would be in for a set of the redesigned ones. Are you thinking of redesigning the extensions or a new inner fender?
I thought when I looked at it the inner fender lip was steel? Seemed like 3" or so that then connected to the metal inner fender, did I miss something?!
