BARRACUDA1968
- May 4, 2011
Not that I don't have enough to worry about getting the car ready for the track Friday night but this oil leak is kicking my a$$. Sorry guy's but I just can't live with leaky motors and the squinting faces I get when people smell me coming.
I've been avoiding what I suspected all along and that was the crank seal. Did the oil dye and found a good leak at the fuel pump plate. Fixed that. Drove some more and more leakage, figured...hoped it was the pan. Fixed that Friday night and drove some more and now it's time to face the music. Off comes the timing cover. I was hoping oil was blowing up there from the IC fan but there's a trail off the crank and I know the pan is sealed.
Going to a 180 thermo and decided to install new Rad hoses so I've got the coolant drained so why not tackle it.
I'm using a Felpro seal and gaskets for the job but since I have gotten different opinions on this I'll ask how you guys' install the front seal. I have the stock cover so it goes in from the back.
Mainly do you use any sealant where the seal meets the timing cover or do you just depend on the rubber to seal between the timing cover and the crank seal?
I suspect my seal is leaking between the cover and the seal not the seal and the crank. I did lube the crank and the seal with oil before I installed the timing cover so I doubt I burned the seal at start up. I did however have a drop of oil on the front of the pan prior to start up. Just primed the motor and installed the engine in the car. Next day before fire up I had oil on the front of the pan. I suspect from the crank seal now.
I only want to do this one more time so throw any tips my way to get this VooDoo possessed TB to dry up.
Thank you!
Thank you!
