I really like that setup the they put together, I just wish it could be put in the stock ecm location. I haven't tried, but I think it will be too big.
I am a big fan of the squirt and the communtity around it,I have been for a while. Not as long as I have been on here, but nearly...
That is one of the reasons Jerry(DIYautotune) gave us alot of the electronics for the TurboFairmont we got in HOT ROD, and won with on DragWeek in '07.
But some of the stuff you have posted for the squirt is still a work in progress.
I.E. the flex fuel was broken in all but the latest firmware, and we can't control the Fuelab pump PWM yet because the frequency is wrong.
A hint on yours, you will probably want to ditch that 2.5 bar sensor, in your pictures, right now if you haven't already. As someone once said,the fun don't begin untill 30 lbs of boost.
BTW,which wideband sensor are you running, I have started to move to the AFX widebands, and they are a little tricky to setup on the squirt, but you get a real NTK sensor, with them.
On my install,
I took one of the TRs that I put a squirt in(msII), and made the setup in the pics, to do testing on the MS3 last year.The long cable is so I can locate the squirt under the pass. seat "ala FastTrack accel gen 7 PNP"
This one now has the ms3x board, and I have yet to put it in a regal with the new 3x board. It ran fine in the "legacy mode" on the ms3 in march/april 2010,this was because we could not get the 3x boards so that was not tested last year.
This year, after the snow goes away, I may play with the coil on plug, but that is down on the list as I have alot to do, and these cars are running and making great power the way they are.
I was at bowling green (GS nationals)this year with some friends, one them won Razor's alky class, one of his cars may get it this year, or after I switch my GN to lsx power, the old Ruggles engine,I take out, may go in a '81 capri to take to Noble this year.
Who is everybody on the MSextra forums, I am Atomicsix on there, just like here. I will keep a lookout to help with problems, if possible.
