How do I know the difference between a 7pin and 4pin? I do not have any ECM plugs on mine. Its just a standard NA pre computer control distributor from what I know.
The wierd thing is no matter where I had my BTM retard set to it would detonate. So there is a small chance it isnt hooked up I dont know. Ive gotta check.
And Id build a knock guage if I knew what parts I need. I know I need a senor, guage and ECM module but where do I get the module? And will it even work with that stuff or is there other stuff? Im not aware of a Non ECM car having any knock guage.
Pull the cap and rotor and look at how many wires attach to the module. 4 wires is a 4 pin ect. What is your initial timing set at first off.
How much advance does the ignition timing have?
Get the directions for the BTM from MSD and make sure you've got it hooked up right. You can download the directions from their website.
You can get an MSD knock guage with sensor from full throttle and you really do need one.
