Well, the car is back up and running at 100%! Woo!
Ive also been without a puter for a week, but im back to normal now.
I swapped the modules out and what do you know, it ran. Had the issue where the BTM wouldnt let the car idle under 1400 RPM. Couldnt figure it out, Had good voltage, would run through the jumper cable everything. I threw the old module in from when I replaced it back in July thinking it was bad when I got stranded due to a bad coil and its all good now.
If you have MSD BTM issues, its possible that your module doesnt put out enough power to run the BTM. I had a Napa echlin one in there. I really want to turn it up to 11 PSI but I dont think the trans can take it. It pulls from 40-85 HARD. 0-40 not so much. Damn airplane gears!
