Details of the run:
60' 1.656
330' 4.873
1/8 7.566
MPH 91.08
1000' 9.888
1/4 11.837
MPH 115.04
TTATony
EMPTY WEIGHT:
BLOCK: STOCK
HEADS: STOCK
TRANSMISSION: STOCK WITH B&M COOLER
TORQUE CONVERTER: STOCK
DIFFERENTIAL: STOCK
INTERCOOLER: STOCK
THROTTLE BODY: STOCK
RJC POWER PLATE: YES
INJECTORS: 009 42.5#
THERMOSTAT: 160 DEGREES
TURBOCHARGER: TA-49
VALVE SPRINGS: STOCK
MAF: STOCK
DOWN PIPE: TERRY HOUSTON WITH OPEN DUMP
EXHAUST: STOCK FROM DOWN PIPE TO MUFFLER
FUEL PUMP: QUAD AIR XP PLUS
FUEL PRESSURE REGULATOR: ADJUSTABLE
FUEL PRESSURE: 43#
ALCOHOL INJECTION: NO
PROPANE INJECTION: NO
NITROUS: NO
CAM, RODS, PISTONS, RINGS, MAINS, OIL PUMP: STOCK
AIR FILTER AND AIR INTAKE: K&N 8" CONE FILTER
TIRE DESIGN, SIZE & AIR PRESSURE: MICKEY THOMPSON ET
STREETS 26x10.5x16 WITH 12# PSI
AIR BAG(s): NONE
SCAN TOOL: SCANMASTER 2.1
FUEL: UNOCAL76 114 OCTANE LEADED
CHIP: BY ERIC AT TURBOTWEAK
CHIP TIMING: 26 DEGREES
KNOCK RETARD: 0 DEGREES ENTIRE RUN
OXYGEN SENSOR VOLTAGE: 764 MILLIVOLTS AT THE TRAPS
TRACK ELEVATION: 1250'
TEMPERATURE: 67 DEGREES
PEAK BOOST: 25#
BOOST AT LAUNCH: 10#
MILES ON THE CAR/ENGINE: 17,135 ORIGINAL MILES
60' 1.656
330' 4.873
1/8 7.566
MPH 91.08
1000' 9.888
1/4 11.837
MPH 115.04
TTATony
EMPTY WEIGHT:
BLOCK: STOCK
HEADS: STOCK
DIFFERENTIAL: STOCK
INTERCOOLER: STOCK
TURBOCHARGER: TA-49
MAF: STOCK
FUEL PRESSURE: 43#
NITROUS: NO
AIR BAG(s): NONE
PEAK BOOST: 25#
