somtimes you can find a small local glass shop and they will take it out for little of nothing rear glass is about 112.00 new replacement just a suggestion with eveything out if you had a small sand blaster you could clean up back seat pan and trunk surface rust pretty quick also down inside rear fender wells lot of rust there most of time then clean out lose or old seam sealer reapply seam sealer
one more sug after you spot weld everything back in sand blast welds ,metal prep solution then self etching primer after that then cosmetics
just a thought
just a thought
