1KWIKSIX
- Sep 29, 2007
That's a beautiful looking setup. Getting fluid moving and things to bleed has never been an issue. Just getting the pedal right at all. How much line modification did it take to get the adjustable PV in place?
The Wilwood adjustable PV can be ordered with the pre-bend SS lines which connect directly to your master cylinder.
I made up a front and rear brake line exiting out of the adjustable Wildwood PV. I wound them like a coil for a few inches to absorb any movement (kinda like the stock factory set up) and made a 45 deg bend going towards the firewall into wildwood residual pressure valve(s) (2# for fronts & 10# for rear).
from there the new front line was made up to connect to the front teeing them together and the second line made up to connect to the brake line that previously connected to the factory PV. I needed two brass adapter fittings in order to make the connection due to the different brake line sizes used in the rear. These were readily available on line. Not too much difficulty.
I can definitely say "the juice was worth the squeeze" !
