Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Fwiw. Here is a pic of the current setup.
SignUp Now!I used the pn for the 84 GN.What is the donor car for these kits? Buick Roadmaster?
Nice and clean looking, please let us know when you solve this issue, and you will solve this!!Fwiw. Here is a pic of the current setup.View attachment 283972
ok. I had a silverado with hydro boost. With no air in the system the pedal was soft, but the braking power was very, very good despite that. Other cars with it I test drove always seemed to have a different pedal than vacuum or powermaster.I used the pn for the 84 GN.
I tried the plugs a while back on the old MCs, which is how I determined they were leaking internally.You have a real head scratcher with this one. I have an idea that should narrow it down to either the brake hydraulics or the HB unit.
Remove the two lines from the MC and plug the MC ports. Now try the brake pedal, it should be high and firm. If it is then the brake hydraulics are the cause. In this case unplug one port and reconnect that line. Try the pedal again to find out if it is the rear circuit or the front circuit that is the cause.
If the pedal is still soft with both ports plugged then the HB unit is bad.
RemoveBeforeFlight
Great suggestion.Jerry,
Here's a suggestion:
How about trying to bleed the air out of the brake fluid via the master cylinder by using vacuum?
Kinda reverse bleeding, but might get the air out your set up. Will just need to make up some sort of master cylinder cover that will accept a small vacuum hose & will enable you to pull vacuum . Maybe these are already available commercially ? Dunno...just a thought!
I have a pressure bleeder and this is exactly what I am thinking about doing next. Thanks for the reply.OK, so with both ports plugged the pedal is good. I would connect one line leaving the other plugged and see what that does to the pedal. To see if it is either the fronts or the backs or both.
A while back with a manual brake setup I had a hella' of a time getting a good pedal. The system had been open and the lines and such were empty. What it took was a pressure bleeder. I used a small garden sprayer for the bottle and charged it to 15 psi from the air compressor.
I didn't connect it to the MC, I connected it to each line from the MC (one at a time). As I opened the bleeders used a soft hammer to bang on the combo valve and the various lines. It took quite a bit of fluid to get all of the air out. Was also recycling the fluid as it was new & clean.
Eventually I got a good pedal. Right before that the air exiting the system was the smallest train of tiny bubbles.
RemoveBeforeFlight
Sure hope so. Lol.To clarify,. The hboost unit is suspect? Sounds like you might wrap things up soon! Here's hoping!
Mounting is correct.Without looking to see if they can be mounted on the wrong side of the vehicle, are your calipers reversed? When you mentioned you had to remove calipers to get the bleeder on the top made me think maybe they were reversed. Normally the bleeder should be on the top.
