SignUp Now!Before I post any pics, let me explain the research I went through which led me to choose the components I did.
I visited some racing chassis sites that listed 4 link kits. The minimum OD for tubing I found to be 1 1/4".
Using chromoly 1 1/4" OD with a .120" wall thickness as my spec for tubing, I picked out high tension rod ends that fit the tubing. The rod ends I ended up with are QA1 Endura high tension alloy steel.
The thread size is 7/8" and the hole through the rod end is also 7/8". I had an option of going with a hole that matched the new planned bolt size, but I decided to make the locator bushings stepped to fit into each side of the rod end ball. Not just but up to the rod end ball.
I found that the bolt size should be a minimum of 1/2". I decided to go with a 7/16" bolt size. Building in extra capacity is never a foolish thing.
Correction! The bolt size I went with is 9/16". Not 7/16".Before I post any pics, let me explain the research I went through which led me to choose the components I did.
Here's my hand for size comparison.
Well,... thank you for noticing. I did clean my nails before the pics.:tongue:Don I think hand modeling is in your future...:tongue:
I don't believe so. They can be ordered with grease fittings. I chose not to because of the change in load rating with a grease fitting. It's like U-joints. You start drilling holes through components and the holes weaken the component. If you're looking for the best strength for the size, you don't want grease fittings.Are they rebuildable like the rose joints Don?
I think my hands are pretty average. I'll get a pic of them next to the stock control arm when I get it removed from the car.Can we get another pic with something we know the size of.......like a beer can? You may have REALLY big hands or something.![]()
I'm gonna bet it has some sort of nylon/teflon insert in them. If that's the case the zerks would be a good idea. I've seen some of those bushings wear out quickly depending on use.
