Head's Cam Lifter's Turbo Ferrea Valves
87chrisss
BLUBYU
package deal if anyone interested $650 shipped for everything
or will price everything seperate
Resurfaced Bare 8445 heads extensive port and polish work.. $300 shipped
Ferrea race valve's int/exh NEW IN BOX $190 Shipped
Lunati Cam p/n 32508 very little street use comes with matching lifter's and springs. info attached $150
Hydraulic, fair idle. Killer street/strip cam for turbo applications.
  • Advertised Duration (Int/Exh): 260/255
  • Duration @ .050 (Int/Exh): 210/205
  • Gross Valve Lift (Int/Exh): .456/.440
  • LSA/ICL: 108/108
  • Valve Lash (Int/Exh): Hyd/Hyd
  • RPM Range: 2500-5500
Stock Rebuilt turbo used less than 500 miles very nice, no smoke almost no shaft play very tight..inlet bell has been ported its very nice turbo no wastegate actuator $175
Hi. What kind of work will be needed before the valves can be installed? Are the exhaust guides already machined for valve seals? Thanks.
