SignUp Now!If I go to target it's gonna get expensive I'll have to sneak out there saturday
This stuff good? I have no info on it.
Pardon my ignorance here, but is this the stuff I need to add to my daily driver's oil to prevent issues w/ my flat tappet camshaft later in life? :biggrin:
kirban 2 cents worth
Guys....its real simple....
zddplus which has been made possible by one of the biggest if not the biggest supporter of turbo regals has the exact formula in a handy 4 ounce bottle you can buy from almost every major buick vendor that supports this forum and has put up for the TSA class about 10 grand this year. A bottle is $10.
The 4 ounce bottle of zddplus contains nothing that was not in your oil originally back in 1988. One bottle treats a normal 4-6 quart oil change letting you use whatever oil you have always used. STP is not the answer you seek.
We sell direct to cam companies such as Isky, Crower, private label for Erson.
Many many engine builders some building 1,000 plus HP engines with roller set ups and have seen a reduction in cam scuffing etc....Most of you realize companies like Isky and Crower have been around for 50 plus years and would not endorse and buy this product from us without doing their homework. Nor would we be able to get as a spokesperson Don Garlits if the issue was not real and if we did not have the easiest solution for owners to use.
You can't improve on what we have period. Its the perfect concentration in our bottle. Can't make it an easier. We sell to some of the largest mail order companies in the US. Eastwood, Moss Motors, Year One, and Buick vendors G Bodyparts, several builders of Buick engines as well.
I don't think STP put up 10 grand for any Turbo Buick class lately at the GS Nats......
Don't believe me? If it had the levels zddplus that you need it would have to state somewhere on the bottle not for late model applications because of the warranty issues for emissons relate to the catalytic converter. That is why zddp has been greatly reduced in current SM oils to approximately 800 ppm.
We have all the tech info to back everything up......
kirbanperformance.com
denniskirban@yahoo.com
The lack of zddp in todays oils is "real" ask any engine rebuilder.
Life is a gamble as they say, but here is one sure method to take the gamble out of the equation concerning your turbo engine.
The largest seller of zddplus in the country...period.
YA,,,,,and where do we poor canadians procure such a fine product...
Guess what roller cam with current sm oil....still not good. We have a engine shop that builds 1,000 hp engines tears them down and has notice a reduction in scuffing using zddplus in the oil....I have proof of that testamonial company actually has built engines for magazine cars.
Roller set ups need zddp......
send me pm denniskirban@yahoo.com with your name & address and I will send you that testamonial....
They don't need it as bad flat tappet cams though. How on earth do engines (millions) survive without it?
I will keep YOUR ZDDP product in mind when I go through one of my spare engines and stick it in the buick.
Does the testimonial also come with a 4oz sample of the product? Thanks:smile:
thing about this for a minute....
its true millions of cars survive without it...however the sm oil with the greatly reduced amouts of zddp has not been out that long...so yes cars up until over a year ago had no issues...and grand ma and grand pa in their cars will never have an issue as they are not performance engines.
Your telling me for $10 you are not willing to protect your investment?
Here is another fact!
My source had the break in oil from a 2007 vette zo6 tested.....from the factory that oil contained 3,000 ppm of zddp....the new oil available has about 800 ppm/......
kinda like smoking....you may make it to old age but the numbers are against you.....once wear starts adding our product later will not reverse the situation.
Their is nothing in our bottle that was not in the oil originally.....the guy behind it has more GNs and GNXs than most and he was concerned enough to have it produced and marketed......
You need to decide if its worth $10 that we are rite......
