SignUp Now!Do not....... and I repeat, Do not wrap the headers. If you get any oil leaks, the wrap absorbs the oil and eventually it will light on fire. If you want the thermal properties of wrap, get the pipes ceramic coated.
I have my dp wrapped with that tape like wrap i ordered on line (wich you can order in many colors, also i wrapped the hot side of turbo w/ a universal type blanket if you will & man what a differnce in uner hood temps. Before all of this if i opened hood at a local cruise upon arrival it was like standing next to an oven, now you can open it and actually grab both with your bare hand for a short time.I would highly recommend just m.o.p. if you want info. for there web site send me a pm there site also shows temp ratings and all related info.
I use a turbo blanket and a wrap on the DP. I have notice a drop in under the hood temps of 250 degrees. I used a heat gun from the same distance pointed at the turbo after a hard run. before and after.:biggrin:
I totaly agree with that, mine are powder coated.
