sean lawrence
- Jan 13, 2013
well i have been restoring my 84 gn and my buddy has been helping me, so long story short while i was doing other things to the car i asked him to install a new coil pack on the car for me the previous owner said it was going bad and so he did and now the car will not fire up. it does not get any spark now or injector pulse, the car has had the conversion to the 86 87 coil pack and module and pig tail by the previous owner and was running fine before the coil was changed. here is what happened when he changed the coil he took the pigtail conversion out and just plugged in the harness straight to the module i dont know why but he did and that is when it would not crank and did not have any spark or injector pulse. i have got access to alldata and checked the wiring diagrams i checked all fuses and there good also checked the orange wire off the battery with the fuseable link and its good as well. then i checked the power to the ecm there are two spots a6 and i forgot the other one i think it was c16 it had 12v but a6 did not which was weird considering the orange wire was good and fuseable was good and thats what feeds a6 the memory power also it splices and goes to maf and esc and ing module and all of them had 12v so i could only think that it had a short or broken wire somewhere after the splice going to the ecm to a6. well thinking i had found the problem i cut a6 and wired it straight to the battery and tried to crank the car and still the same result no spark no injector pulse. i think when he plugged in the harness to the module without the pig tail conversion it sent back voltage to the ecm and fried it. i took the ecm apart and inspected it and it looks good nothing burned and no burnt smells but that does not mean a whole lot. i put a ecm on order at oreillys and should be here tomm morning and i hope it fixes it but i am not holding my breath. please help i really dont know what to do next and this is my first gn so im a little in the dark here but learning quickly as you can see. this does not make any sense to me has anybody else made this stupid mistake and if so did this happen and if so what did you do to fix it? thanks any help would be great. sean
