Looking for a little help guys. A few pertinent things to tell you about that aren't in my sig. About a year ago I replaced the plugs with Autolite 23's, plug wires with High Boost wires (8.5mm I think), and the coil pack with an AC Delco Chinese coil . Had fuel pressure problems recently, so I decided to change pump and convert to E85. I now have 2x255 Walbro's, but I'm only running one for now until I go bigger. FP is keeping up with boost fine - I've been obsessed with it since I found my bad pump. Somewhere in there I also installed Comp 980's and an RJC Power Plate. (Note: when I did that, I noticed some oil going into the TB from the PCV, which I understand is pretty normal. I plan to put a catch can on there soon to keep the oil out of combustion chambers.)
So anyway a few weeks ago, I went to the track to see how all this played out in ET and MPH. I was pleasantly rewarded with improved times of 12.87 and about 104 mph. Zero knock. 22PSI boost. Stock turbo and IC. I only drive the car occasionally, so about a week after the trip to the track, I was cruising around at night and notice a couple of puffs of white smoke out the DS tailpipe at a light. I thought "I have GOT to get that catch can installed". Next time out about a week later, same thing only a little worse PLUS I also noticed a smell of burned oil PLUS I noticed my boost at WOT was down to about 19 PSI. I pulled over and checked the RJC Boost controller & it was still screwed all the way in. I thought this was weird so I took it apart and stretched the spring a TINY bit (also noticed some oil on the ball inside it). Got back on the road and back to about 22PSI. Still smoking at lights. Still thinking to myself about the catch can.
Fast forward to tonight. I take the car out and smoke still there (as I expected, it has not healed) at idle and sometimes I noticed it at low speed. I can't get boost to stay above 18 PSI. I switched pumps over to the "other" one in my double pumper system. Same deal - 17-18 PSI. O2's are OK - no knock, but car feels very weak since it's not developing the boost. Checked the oil and it's NOT milky. Any help on possibilities? My thoughts are below.
As far as SMOKE goes:
1) Turbo seal is bad. I think this because it's a stock turbo, I been running it at 22PSI, I found oil in the boost controller, and smoke out the tail pipes. I have not pulled any hoses off post-turbo to look for any oil. However, I'm thinking that any oil that is going into the compressor side will collect in the stock IC - basically making my IC the "catch can". How could oil go UPHILL into the TB.
2) Super bad PCV? Thinking about it now it really doesn't make sense. I'm just brainstorming I guess.
3) Rings or valve seals. When I changed out the valve springs, I was told by a couple of VERY well-known mechanics on here to just leave the seals alone. I didn't mess with them. I sure hope it's not rings. Any suggesstions?
As far as loosing boost pressure (I'm really stumped here):
1)Will a bad oil seal in the turbo cause an inability to build boost? I wouldn't think so. I had already decided I was going to get a new turbo anyway as I've maxed out the stocker. I don't think buying a new turbo is a good way to tell if you have a bad turbo seal though. Is there any other reliable way to tell?
2) cracked header(s). I checked around in the dark with a flashlight and didn't see any. My car still has the stock heat shields tack-welded on. It's tough to see. The original owner told me that he never had them off to repair cracks. I believe him. He was very honest and upfront about the car when I bought it - I have not caught him in a lie yet after almost 2 years of ownership. Just exactly WHERE on the DS header is the crack-prone area? I know guys say between 3 & 5, but is that typically under the heat shield? Should I just bust those off? I really would like to stay stock appearing.
I will say that I went through the SM numbers at hot idle. Everything seems to be in line - BLM = 129, IAC might've been a little low at 25 (maybe not). Not overheating - idle temp tonight is around 171-173. During WOT, I verified FP to boost climb and that TPS was going up. It typically went up to like 4.56 to 4.62 at WOT.
Any help or thoughts? Especially about how to tell if I have a bad turbo seal. This has me worried due to the smoke out the tailpipes
Thanks in advance.
Thanks in advance.
