Grumpy Do you gamble?
NO I do NOT.. Work to hard for my $$$ . Oh I did go to Vegas in Nov an blew $4.
I guess winter is officially here
SignUp Now!Grumpy Do you gamble?
I guess winter is officially here:biggrin:
Your cash vs. His time...that already sounds bad....:tongue:
And other info from the machine shop yet?
I am going to leave it at STD, the mains look good too.
so you goin to use stock pistons ???![]()
Nope, i will be buying these
6-SLP-R-10499 Piston Rings-------$119.95
7-TRW-L2481F Pistons-------------$311.70
Just waiting for the go ahead from the builder.
what are you going to do with that extra piston?
OK here i go again.
I have read in a few threads that the timing tabs on the balancer are off by a few degrees is this something that should be looked at or not even bother for this type of build.
What benefits are to be had by correcting this?
How far off (degrees wise) are they usually?
I have heard of that but never checked one. In one of the treads it may show you how to check it. So... $300 for standard pistions... Man, that money could go towards an HR parts bar. If you crack a stock piston on a car with Felpro head gaskets, alky, scanmaster, working knock sensor and a 11.50 combo you will damage a forged piston too.
I have never had a problem with the stock balancer nor have I heard of one .. SFI ones ...YES !!! Send them to Dan @ DLS ..
....$300 for a set of forged pistons??? sounds cheap. NO other comment at wasting $$$ at this time. Those stock pistons can't take a beating![]()
Budget build... stock pistons that pass the visual inspection. That why they say budget builds aren't expected to be fast and reliable. It may fly a few times then pop. It may last a few years of normal use. Get my drift...
Some one mentioned those piston to a few days ago, i never heard of them before that. Thanks for the reply and the link.Here's a set of forged pistons someone had posted before, they are $350 14477 - Buick V6 -29.5cc Dish Top SRS Pistons
a mid 11 car can last years !!! been there an done it.. 218k on one of the cars before it broke a crank (Melissa's Limited T)Plus we did a lot of what I call the "haircuts and a shave" or the .. "wam bam thank you mam". These motors will take a beating and come back for more
True Grumpy. I was talking about the cars that go low tens in full weight cars on the stock shortblocks.
ok !!! then its a grenade waiting for the pin to be pulled.
.....on the cheap rebuild I still had the machine shop mag, clean an hone the block. Mag an polish the crank. Check the big ends on the rods.![]()
