So why throw more parts at it?? Keep what ya have a play with the TT chip .. come on there are only so many variations in the chip. BUT before tuning everything in the car has to be up to snuff or it won't work no matter what parts ya throw at it.
..This thread is like driving by an accident.. I have to turn an look
...oh ... I only work on my own junk since 2000 (I think). Trying to figure out why a car doesn't do what its suppose to do can be a real PITA because ya have no idea what else was done an IF it were done right.
Just in case i left it out of the list
I will be reusing ALL of my current accessories(Turbo, Injectors,Chip and EVERYTHING ELSE.
Its all good Grump i understand "playing it safe" and staying away old junk wouldn't want to ruin your rep.:wink: Grumpy Do you gamble?
Grumpy, this thread has been going on since 10/08. That's over 2 years to fix issues rather than rebuilding just to go 11s. You can lead a horse to water but you can't make it drink.
Hey garrett, after 2 years how's that flat tappet cam doing?
You guys are TOO funny.
i had abandoned the idea of the rebuild some time ago. when i started getting the "you don't need This" and "you don't need that" and the big "work with what you got"
So like the gods suggested i ABANDONED the rebuild idea and worked with what i had (TONS of BLOW BY, loud as s lifters) .I had so much blow-by that i had to wipe the valve covers just about every time i got into boost. OHH i should have tunned out the Blow-BY RIIGGHHTTTT.
So i then went ahead and worked with what i had and proceeded to go to TWO track rentals and showed improvement each time.:biggrin:
DUUUUHHHHHH
BUT after I BLEW UP (LOWER END KNOCK) THE ENGINE i picked up this thread where i left of instead of starting another one.
So now working with what i have, should i just put some heavy oil in it and go make some WOT 25 PSI runs?????
i know i am not as smart as you guys and i ask a lot of questions and i am "ridiculous" but please help me out here Should i run the car as is????
What performance parts am i adding to the build?
A roller cam??? OHHH i should go flat tappet instead
The heads i have them out and they are going to the machine shop for a cleaning and rebuild why not do a little something to them??? OHHHHH i should put them back on as-is then take them back out and do the work to them and in the proses pay for extra head gaskets and every thing else that comes with doing the job
AND if i don't do the extra work while i have everything out i'll get the "you should have done it while it was already out"
Sorry but here comes another dumb question.
if i do a slightly larger cam and some better flowing heads shouldn't i be able to run the 11.50 that i am looking for with less boost??
Is running less boost safer?
