Kent Buckles
BBBAAD 6
- Feb 8, 2002
I have seen some other threads related to this and have been on the hunt for the problem for a few weeks but no luck. Anyone with any input on your expieriences or references for this problem is greatly appreciated. I am blowing the ECM/SOL fuse which is in the upper right hand corner of fuse block. The fuse blows as soon as the key is turned on. My scanmaster then shows an error 31 and the SES light comes on when boost is built up of course. I have unhooked the purge canister, egr, brake pedal switch, wastegate selenoid all at once and same thing happens. I believe all of these things are on same fuse. I am assuming I have a short but could in be another swich/selenoid? Anyone with places to look for shorts? I have checked the obvious and do not know where to go next. I have also noticed that my manual turbo boost controller on dash is not working now also and could this be related? Also any way to wire around boost selenois so I can exceed 10 lbs of boost until I figure this out??? THANKS, Kent
