just plain john
El Camino a Go-Go!
- Feb 24, 2007
I have an idea for a fuel pump circuit and would like some feed back. I propose to take 2 #10(fused + and -) wires directly from the battery down the frame rail to a frame mounted relay. I'm going to trigger it with the factory wire extended to the new relay location. I'll switch the positive with the relay and use the negative for a known good ground. Sound about right? Before anyone asks, there is no circuit to begin with in this hybrid build so a hotwire won't help. So what components would be needed? Fuel pump pulls 30 amps, right? Any guesses if battery voltage would be adequate at the pump with this method? Discuss...
