I just had the converter changed from a stock one, to a 3200 lock up vig, now the car will not shift at wot, it was fine before the converter change,
the gov. spring in on...
it will shift at normal driving ???
any thoughts????????????
chris
if you floor it, it will take off and then hit the rev limiter,
let off the gas and it will shift.
the trans is not slipping, ????????
thanks for any help, you might have.
sounds like it needs a lower tv adjustment or the governor is too light for the intended application.did anyone have access to the trans when the convertor was swapped?
