Hi all, I'm really nervous here. Here's what I've got. Fresh rebuild, turned the crank, and resized the rods. Have Wiseco .020 pistons and new lifters on a 1000 mile 204/214 cam. Everything is attached and ready to start. Stock turbo, MAF, etc. Got straight 30 weight oil in it with some GM EOS and some molly and assembly lube in there. The Oil cooler attachment is removed. When I start the car, the oil filter (PL10111) will start to turn and spew oil if I try to bring it up to break in speed. I have started the car 4 times for less than 30 seconds each.
I have modded the front cover to Earl Browns specs (1/2 inch holes for the oil feed) I have a metal plate on the oil pump, which is stock. What can I do to troubleshoot this? I don't want to break my new motor! Could the machine shop have left something in the block that would cause this? I have the weakest spring in the oil pump for the bypass. It's a lot weaker than the factory spring.
Help!:frown:
Help!:frown:
