Help to much retard
Stealthfxxr
Getting way to much timing retard at 10 psi when i accelerate ( actually went to 30 degrees at one point). neet to know wut to try fp tlink said fp could be too low or 02 sensor. Any other suggestions?
Dale
You are probably getting false knock if its that high or the tlink is getting crazy info, mine is doing the same thing, You would probably not even have heads on your car any more if that was real knock. make sure every thing is tight , down pipe and the cross over pipe, make sure its not hitting the oilpan.
my tlink was saying that i was getting 30-50* knock retard to, now i need to send the cable to them to be checked out.
