sent you an email and some pics
razors instructions with the alky kit are very clear on how to connect the map and where to connect the map output , in your case just follow directions for gnx /digital dash cars
when you finally have it wired be sure to verify 1.6v at the green wire at the PAC controller (key on engine off) so that you can be sure that ant connections you made to get to the PAC are good
