As if you're not busy enough I have an idea for another new part...
I was just out in my shop looking at my old TA-60 and got to thinking about the limited stock housing turbo selection currently available for the hotair crowd.
Then I got to thinking that the only thing keeping hotairs from running reclocked 87 turbos is a couple of simple aluminum adapters.
The first would look just like the stock turbo to intake adapter except in place of the turbo side o-ring groove you have a machined hose barb.You plug that sucker into the intake,clamp a piece of silicone hose to it and shove a reclocked 87 turbo outlet right down into it.Clamp it down,done deal.
The other piece would be just like a piece I(and a few others if I recall)had made a few years back.It would be an adapter similar to the one you're probably already looking at with your intercooler kit to rotate the throttle body back around to it's proper orientation.
If you made this simple kit with the required replacement o-rings so the average hotair guy could easily bolt on any 87 style turbo I think you'd sell a ton.
.If you went ahead and tapped that adapter and included an alky nozzle I have a feeling you'd REALLY be cookin with gas
:biggrin: .
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
![Cool :cool: :cool:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png)
![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
