Not many takers on the low compression side.....thought there may be a couple of 3HP per cube (or more) guys out there.
This keeps taking me back to a conversation with  Ricardo La Costa 10 plus years ago where he said "They think I'm crazy but I love compression". For those that don't know him he was going 8.30 a long time ago....stage stuff of course.
More compression will let the power happen somewhat easier and with some positive side effects as already stated....
The gap will widen some as you push the turbo harder and approach the limits of the turbo/ compressor and turbine side limitations and efficencies....think less charge air temp from a lesser boost number and lower IAT,s that come along with it for free.....and possibly less turbine drive pressure since you are at a lesser manifold pressure for the same or more wheel power numbers.......Also the ability to use a bigger exhaust housing without killing the spool.....and converter selection can be tighter as well.
Cylinder pressure and the length of the pressure wave in the cylinder make engine torque and the way
that the pressure is generated makes a difference.....
25# boost with 10-1 may make the same cylinder pressure as 35# with 7.5-1.. which one makes more power will revolve around the air temps,drive pressures cam timing and so on and if you take advantage of the beni's that the higher CR can give you....
Supposedly turbo engines benefit from their expansion characteristics in the cylinder by having a somewhat higher
cylinder pressure at the tail end of the Useful part of the downward stroke meaning they can produce useable cylinder pressure for a few more crank degrees.... The deal is pretty much done by 70 Degrees ATDC.
Nitrous and NA engines build the pressure a little bit different than the boosted engines......why do you think the blower cars are so damn loud at the track?? Cause when the exhaust valve cracks open their is way more cylinder pressure than a NA car but the pressure is down to a point it does not produce much usable work on the crank so they begin to empty the cylinder early......
The N2O engine we are building which is a serious but not all out race piece will have the exhaust valve Open
.085" at 95* ATDC on the power stroke.....When the piston is only half way down.....the reason I bring this up is a higher compression lower boost engine may benefit from the exhaust opening event begining a few degrees earlier
since their is less total air in the cylinder to expand and drive the piston down than a low CR Turbo engine......we are talking small changes here but if you are purpose building a high compression turbo engine why not go for all you can get?
But if you are going to be more of lesser boost say 17 to 22 pound kind of deal you can pretty much make up the power difference with some extra manifold pressure to make the power but you lose out on the other free benefits.
With that said my 8.2-1 CR  233 inch with an 18 blade ptc on a 94 degree day spooled my 71HPQ BB very fast And launching at 5# boost was at 30# boost in 5-7 tenths of a second.  [.5 - .7 ]......I used a TA 3 1/2" pipe with a 1.00 inch hole in the housing a High pressure actutor and a Perrin adjustable controller and had great boost control...+ or - one-half pound.
My next engine will  have more Squeeze and be much more purpose built But unless you want to scrape up an extra grand for new pistons and fitment you can get along with what you have except maybe that 17 blade.   FBR
