No disintegrations
 - Dec 27, 2015
Pretty low, in the teens.I'm interested to learn what timing high compression builds get away with.
SignUp Now!Pretty low, in the teens.I'm interested to learn what timing high compression builds get away with.
A lot more than you think with the right fuel and tune.I'm interested to learn what timing high compression builds get away with.
Lots of factors but we run high comp motors a lot more aggressive with the right build and fuelPretty low, in the teens.
So I've been hearing of timing closer to 20 with 30psi of boost and high compression.Pretty low, in the teens.
bottom line is the dyno is great for finding a good number for timing. go with what makes the most torque then back off a pinch.I feel like I should go with 10:1 instead of 9.5:1
The pin bosses,of those pistons,have a lot of girth. Since the rods don't reside in the center of the pistons,you'll want to make sure the rods don't hit one of the pin bosses. I'm using these Racetech pistons and had to remove material from one of the bosses on each piston because the rods were hitting or too close.I just got my final numbers in and I'm going to be at 10.5 to 1. I'm running e85 for fuel . This picture is of my rod mocked up in its home . my first attempt I had the piston in the hole .125 @TDC which wouldn't have worked lol now with a new set from earl I'm at .003 in the hole![]()
I had to remove alil from both sides of my rod to get the .040 clearance all the way around . They are beef cake right there thoughThe pin bosses,of those pistons,have a lot of girth. Since the rods don't reside in the center of the pistons,you'll want to make sure the rods don't hit one of the pin bosses. I'm using these Racetech pistons and had to remove material from one of the bosses on each piston because the rods were hitting or too close.
Improved mass flow at lower pressures substitutes for a lot of boost and timing constraints.I had to remove alil from both sides of my rod to get the .040 clearance all the way around . They are beef cake right there though![]()
Could use either. Have a new pair of GN1’s I could put together or use a set of irons11.5:1 sounds interesting... iron heads or aluminum?
