Here's another little tidbit you don't know.... I've forgotten more about this stuff that most people will ever know... and I am CERTAIN I don't know shit!
When it comes to cams, there's one steadfast rule: Once you know a lot about that subject, all you know is that there's a LOT you don't know!
Tyler, basically it works like this. If you take an optimized engine and but a huge 'rump rump' cam in it, you just made a lazy dog. When you put a fat ass intake lobe in there the piston is halfway up the bore before the intake closes, THEN (and only then) can you start building cylinder pressure. A huge lobe in an 8:1 N/A SBC, just turned into a 4:1 ''hot rod''.
So you have to bump up the static compression to end up with the same cylinder pressure you had before. The upside of doing that is you now have an engine with much less cylinder dilution and less 'dead air' space during overlap. That means even though you given up some of the stroke for squishing the A/F charge, you know have the ability to suck like a Thai hooker during overlap and get more A/F in there to squich (without going over the octaine limit of the fuel).
...now here's where it gets good.... All of that above example is WOT. And most of the time that's all anybody talks about.|
In real life we drive under vacuum most of the time. The static and dynamic are artifically starved during cruise. A tank full of 87 could live just fine in a 14:1 engine if you never went full throttle. As long as you never let it get full, it won't detonate itself to death. The trick is to have an engine that's not a dog while being 'starved' at cruise, but really gets on the clock at WOT.
You can build the most efficient, super neat, awesome WOT combustion even ever known to man..... ....and still have a POS if it can't act right at the other 99 points under the curve.
That's where higher compression shines. When 'starving' the engine of a full charge, the extra squish allows it to still move the car with very little throttle opening (non-car people call that 'gas mileage' and 'throttle response'). Then when you crack the throttle the engine springs to life on that exact intake stroke. In the case of a turbo motor, that means you start spinning the wheels right then, and spinning them harder due to the stronger exhaust pulses.
Now what's really cool about out turbo engines, is we can adjust the exact cylinder pressure we want by turning a screw. N/A guys don't have that option so they have to guess low (and hope they got it right). Granted you can't make as much boost with higher compression, but you can achieve the same thing with less boost, load, time, inefficiency, etc.. Bragging about boost levels is for ricers and bench racers.
Boost is a measure of how much air you couldn't get in the cylinder. In a way that's like paying a prostitute more than the asking price, and not getting laid.
....then bragging about it.
My advice is to learn as little about cams as possible. It's just easier that way. The 206/206 is an awesome piece that can get the job done.
Oh on an interesting parallel, my piston engineer was Duttweiler's piston guy in the 90's. That made working with him and building my plans were so much easier (once I convinced him that we don't really bust slugs like the average dumbass. We're above average!
