SignUp Now!http://www.turbobuick.com/forums/general-turbo-buick-tech/296611-tuning-117-race-gas.html......... I have a dual nozzle on my car and last night the charge air temp was less than ambient at 20psi on the highway after about 2 seconds of WOT. You should relocate your ATS so you can get an actual number and crank the alky up to pull the heat out. The ATS will let you know if you are going in the right direction as you increase boost and crank the alky. If you have 20 psi at 5000 rpm and the charge air temp has decreased 15-20 degrees you will pick up power.
Good stuff!Jerryl, great info. I wish I could learn more from you. Car is running 28" tall tires. Converter is not being locked so I know that is causing slip as well. I talked to dusty and he said my converter is doing pretty well since its being short shifted and its hard for a converter to couple when I'm shifting so low and spinning so high. The slippage should go down when I raise my shift points. Next year its a new tranny anyways and one of dustys converters. Also my car weighs 3344 last time out.
Brent
bump for a good read. was looking at this post and was wondering how my data would change since the rear end ratio was off. car had a 3.90 gear and i had no idea. so it appears converter slip wasn't as high as expected. converter slip comes out to 5.2% which is pretty good.
I have more data that i might send jerryl if he wants it. not sure if anyone likes seeing this type of data. new converter is showing 2.3% slip. i have since changed the setting in the controller new tune, more boost, new converter and trans and a few other things.
brent
let me know what data you want. either via phone or email etc. guess this is boring info..
